Stop multiple while loops with one button
Hi everyone,
I have a login subvi and I want to have the user be able to know if caps lock is on while they are logging in. So I have a while loop for the log in portion and a parallel while loop checking if caps lock is on. How do I stop the caps lock loop from running when they log in/ cancel?
Thank you.
Kind regards,
TK
(1,733 Views)
Accepted by topic author Teekayy
The second while loop is indeed being closed by the local variable after you log in/cancel, maybe one suggestion I can make is to add a timeout event and move the code from the second loop to the main one so you can have just one while loop like the image below:
(I also deleted the wait function)
(1,717 Views)
Thank you!
(1,714 Views)
