Stopping wait function
I am using a parallel loops and in some of those loops I
use a delay function.
Is it possible stopping the wait function when some button is pushed( and  when some variable changes its value)?
Leonid
(3,298 Views)
No.
Create your own delay method that only waits a small amount of time repeatedly until the full delay time has been reached, and keeps checking if it should cancel.
(3,282 Views)
You could also use a wait on notifier or wait on occurrence.
(3,278 Views)
As knights said you have lot of methods to achieve that. You could do by this way too.
This would wait for 100 ms but any alarm comes this will stop.
Good luck
(3,270 Views)
      You can use event structure, while you wait (event timeout) if other event occur you can manage it.
Best Regards,
Luis A. Mata C.
Ing. Electrónico
Whatsapp: +58-414-1985579
BBM Pin: 2B83E99A
Thanks: Kudos
(3,254 Views)
Thanks for the replies and examples,
Leonid
(3,227 Views)
