Stopwatch
Hello, I am trying to make a simple stopwatch with start, stop, and reset functions. The stopwatch I made however is not able to be reset as the clock is running. If it is running and the reset button is hit it displayes a random time. If the reset is hit when the stopwatch is off it works fine though. If anyone knows how to fix this it would be greatly appreciated.
Message 1 of 10
(5,187 Views)
Why do you think you need all these shift regsiters?
Why do you divide by 1000, just to multiply by 1000 a nanosecond later?
Did you search the forum for stop watch.
Tick count is random, so you to reset to need to feed the current tick back into the shift register, not zero.
Message 2 of 10
(5,172 Views)
Hi Matthew,
Well, it would be much easier when your code would be cleaned up:
It also would help to provide more comments in the code, especially on the purpose of each of those 3 shift registers!
Message 3 of 10
(5,168 Views)
Here's what I might do.  Simplify! (Do you really need milliseconds???)
(Of course personally I would just convert to seconds (DBL) and use a single indicator using time display).
Message 4 of 10
(5,152 Views)
Message 5 of 10
(5,139 Views)
Don't have 2019... what is the formatting you used for the time display?
Former Certified LabVIEW Developer (CLD)
Message 6 of 10
(5,133 Views)
Hi Frozen,
relative time, HH:MM:SS with 3 digits for milliseconds…
Message 7 of 10
(5,130 Views)
@Frozen wrote:
Don't have 2019...
It would seem more important to know what you have. 😄
Here's a 2015 version....
Message 8 of 10
(5,124 Views)
Thanks!
That is what I was looking for 🙂
Message 9 of 10
(5,112 Views)
You could even get rid of the high precision seconds at the expense of an additional division, like so
mcduff
Message 10 of 10
(5,073 Views)
