Storage VI SetProperty results in Error -2500 (Storage VIs internal error)
Hi!
As mentioned above the Advanced Strorage VI "SetProperty" always results in Error Code -2500 and i do not know why this is the case.
I'm running LabView2013.
I already found some posts concerning this error but they all point to Problems within LabView8.
Attached an example that should produce the error when running with default values.
(2,602 Views)
Accepted by topic author m0w1337
Hi everybody,
I finally found the source of the Problem: You cannot name a Property "Group". So if anybody encounters this Weird Error sometime, try a different Property name. In my opinion, the Error Message appearing is really poor in this case.
Have a nice Weekend,
Moritz
(2,550 Views)
