Store 1st iteration value
@Paige5 wrote:
My problem is that I am reading from an array, so I need to use a for loop. I want the first value of the array to be subtracted from every other value as it comes in.
Thank you all very much for your help!
Look ma, no loop
Message 11 of 13
(2,254 Views)
Accepted by topic author Paige5
Your code is pure Rube Goldberg. Your use of "select" can be replaced by a wire. You can use "delete from array" to get the first element and an array of the rest. Autoindex on the rest after subtracting the first  to play the values in a slow loop or whatever you need to do.
Message 12 of 13
(2,251 Views)
Thank you!
Message 13 of 13
(2,217 Views)
