Hi Christian,
Here's a quick-and-dirty VI to do what you requested. Just replace the in and out clusters with yours. It's quick, as you can see, but "dirty" in that the file will not be readable with a text-editor. ALSO, you won't be able to read the saved data if the cluster type-definition changes! Maybe that's OK. It's a bit (OK, a Lot) more work, but there are tools for saving readable/named settings in FILE I/O\Configuration Files palette. A "slick" way to save info between runs is to store right in the Windows registry (assuming you use Wndows. See Advanced\Windows Registry Access.
Cheers
When they give imbeciles handicap-parking, I won't have so far to walk!
