Store data in a Labview buffer
I was wondering if labview allowed to store data in a kind of buffer or temporary memory to wait for all test complete and then export them to excel using the report generation toolkit ?
If this is possible I would like to know how can I implement it, because I am using the report generation toolkit but it takes too much time to open and close excel for each test to save data.
thanks,
(14,394 Views)
Accepted by topic author Ingenu
Hi lngenu,
You can do this using the shift registers. Kindly go through the attached vi for more information.
Nitzz
(Give kudos to good Answers and Mark it as a Solution if your problem is Solved;))
(14,391 Views)
Thanks you NitzZ, problem solved !
(14,376 Views)
Hi NitzZ,
thanks a lot for your solution, this is useful for me too.
I would like to improve it just adding a control to start/stop buffering and then, after buffering finishes, save whole array in an excel spreadsheet, how can I do it?
Thanks a lot.
Maria
(14,295 Views)
