Store the final result of indicator
I have generated a value let us consider as an indicator now when i run it for the next time the indicator shouldn't reinitialise to zero.Is there any possibility of doing so....
(3,019 Views)
Save the value to a file.  When the VI runs again, have it read the file and write the value to a local variable of the indicator.
(3,005 Views)
Get the value and store it in a file (for instance an ini file) when you close.
Read the value from the file when you start and set it.
(3,001 Views)
If you don't need to close and reopen the VI (more specifically if it won't leave memory between executions) then you could also consider Uninitialized Shift Registers as a possibility.
These are quicker and simpler to set up but are subject to the restrictions I mentioned - they will not retain values if the VI leaves memory.
GCentral
(2,927 Views)
