Storing datas into a 2D array every N cycles
I am trying to save data together with the index every N cycles,then put them into a 2D array,
I managed to save the data every N cycles, but I am having some difficulty of saving them with out the zeros in between.
E. g
i      y  save every 3 cycles      i      y
0     0                                    0     0
1    10                                   3    30
2    20                                   6    60
3    30
4    40
5    50
6    60
7    70
8    80
9    90
10  100
Please refer to the attached VI
Thank you
Message 1 of 14
(4,077 Views)
Accepted by topic author Edwingtr34
Message 2 of 14
(4,070 Views)
Thanks JM,
Thats helps a lot !...
Ed
Message 3 of 14
(4,055 Views)
Hey JM
Sorry to ask you about one more help. Is there any way that I can also limit my 2D array with only the newest 4 obtained data ?
For example that,
when i or the counter = 19, only the index 18, 15, 12, and 9 together with their values are store in the 2d array instead of all of them, as I am trying to used only the newest data for my calculation.
Thanks again ,if you can help me up with this last doubts that I have. I tried using the delete from array block , but I am still unable to get it working right. sorry to ask you for help again , but I am really new to labview....
Message 4 of 14
(4,047 Views)
Array Subset and Array length can help you achieve that.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 5 of 14
(4,039 Views)
Message 6 of 14
(4,037 Views)
Hey Guys,
Sorry to post this question here, but this is related to the same VI
Thanks J. W for showing me how to do the delete from array block, that works perfectly fine.
HOWEVER, when I plot the data on the graph, the plots contradict with the values shows in the table, which I really cannot under stand why this is happening.
Please see attached VI
So sorry to ask this here
Ed
Message 7 of 14
(3,985 Views)
Message 8 of 14
(3,973 Views)
You need to move to index according to the position, here's a quick draft.
Message 9 of 14
(3,960 Views)
Overall, that constant growing and shrinking of the array is not such a good idea. It causes memory thrashing. Better would be to have a constant sized history buffer. Here's a quick draft. Modify as needed.
Message 10 of 14
(3,955 Views)
