Strain Gage Rosette principal strain calculation
I'm using DaqMx to collect strain gage data from a rectangular rosette.
I'm trying to calculate:
Principal Strain 1 and 2
Principal strain angle
Max Shear STrain
Max shear strain angle
When icompare values i calculate manually to values that LabView calculates i get different results.  Can someone point me to a document that describes the calculation that Labview uses to get these values.
thanks,
(2,939 Views)
Check the help for documentation of algorithms. When you say the results are different, are we talking a lot? Are you sure everything is wired and configured correctly?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(2,915 Views)
