Strange Block VIs
Another block on my project is unknown. Does anyone knows how to find this block? Thanks.
(3,953 Views)
This is a property node for a control (implicit binding).
Maybe you should work through the basic LV tutorials. I am pretty sure that these items show up there....
Norbert
Norbert
Expert: Geometry
(3,946 Views)
-That is property node for the image indicator.
-If you have started just learning LabVIEW please check these links:
Start with below links to learn about LabVIEW programming
NI Learning Center
NI Getting Started
LabVEW Basics
LabVIEW Graphical Programming Course
Using the Context Help Window
uday
(3,943 Views)
In addition to the advice mentioned above, if you right-click on a node, the resulting menu usually has a "Help" selection - in the case of property nodes, you will usually get TWO "Help" selections - one for generic property help and one for help with the specific property chosen.
Bill
CLD
(Mid-Level minion.)
(3,903 Views)
