Strange Boolean Value
Not sure what I am seeing here. I created a Boolean from the UI Control Suite: System Controls 2.0 palette (a free add-on) and as I did not like it, I replaced it (by that I mean I used "Replace...") by a System Boolean (a check box):
I created a Property Node "Value" from it and I got this:
In other word, my Boolean is a Boolean AND a Variant... Do I win something special for this one?
A demo VI (LV 2011) is attached.
Note: of course if I get the Check Box System Boolean directly from its palette, things work as expected (i.e. the "Value" has a Boolean type).
Message 1 of 11
(5,465 Views)
Look at the mechanical action on your boolean. The original boolean was latching, which means that it briefly changes the value to true and then back to false. You shouldn't try to read the value of the boolean with this type of action. Change the action to "switching" and you should be fine.
For more info:
https://www.ni.com/docs/en-US/bundle/labview/page/changing-the-mechanical-action-of-a-boolean-object...
Message 2 of 11
(5,464 Views)
I understand the difference between latching and not, what I don't understand is the behavior of the Property Node.
Actually, if you change a non latching Boolean to a latching one, its "Value" Property Node changes to some "undefined" black color (which would in fact be a good way to warn the user):
which no Ctrl-RUN click will transmogrify into the Variant type I was describing above.
The Help mentions that the "Value" Property Node will return an error, which it does in the VI I attached (error 1193, "LabVIEW:  When a Boolean control has a latch mechanical action, you cannot use the Value property to read or write its value").
But there seems to be no particular logic to have the Property Node "Value" be of type Variant.
I want my CAR!
Message 3 of 11
(5,460 Views)
X.
the system check box is a varient because system check boxes depend on the operating system for their representation.  System check boxes don't even require a BOOL representation.  On a Windows 32bit PC this is an unsigned char same as LabVIEW (hence the easy Bool to 0,1 conversion)  On other OS's; a U32? U16? U64? I8? (for mixed check boxes?) I don't really know- its system dependant and I trust LabVIEW R&D to do that work.Smiley Very Happy
Message 4 of 11
(5,453 Views)
Actually, there is. The base class is the Control class, and the datatype for the Value property is ... a variant. When you set the mechanical action to latching, you are seeing the datatype for the base class. I can't say for sure, but I suspect the NI engineers did this on purpose to prevent programmers to try to gleefully wire up to the Value property and get their pretty green wire.
Message 5 of 11
(5,438 Views)
@X. wrote:
I want my CAR!
here you go!
(This bug caused a crash too!)
Message 6 of 11
(5,436 Views)
All good answers above. My point though, was that this behavior does not appear to be documented, at least not in the natural location, which would be either the "value" property node help or latching boolean help.
I know that I need to drop a latching boolean control in the event node that handles it (as examplified in the WRONG VI below - which does not work in the sense that the Boolean is NOT updated):
What I was suprised about is that you have to wait until runtime to be warned about it (and then only if you look at the error output - which I bet very few do - or you watch carefully how the Boolean reacts ..not). I think the black/broken VI behavior of the Property Node, which occurs when you change the behavior from non latching to latching and the Property Node was already here, is SAFER and MORE INFORMATIVE than the one I was reporting. That is, if you drop a "Value" Property Node for the latching boolean, it shows up as a Variant, which at best is "puzzling" for the non-insider.
My 2 cts.
Maybe not a CAR, but at least a BIKE (*)?
(*) Bit of Information, Knowledge or Explanation
Message 7 of 11
(5,404 Views)
You want a prize for reporting something that is well known?
Even if it had been unknown, reporting it wouldn't even be worth a refrigerator magnet.
Message 8 of 11
(5,382 Views)
Which behavior are you referring to? The fact that the datatype is a variant? Or that when you change the mechanical action from switched to latching that you get an "unselected" property (i.e., the "Value" property text is black instead of green or purplish). Or both? I can see where having a little extra documentation certainly wouldn't hurt.
However, I will guarantee you and even bet you $1 that for every person that is able to find out the answer via the documentation, there will be 3 that post a question to this forum before even bothering to look at the documentation.
Oh, and so far, I have never lost my $1 bets. Smiley Wink
Message 9 of 11
(5,371 Views)
The first...and the second...
I actually did not check the documentation until after I started receiving some feedback and explored this latching boolean struggle within LV (at least as I could reverse engineer it from reading the Help file:
- NI1: We can't read the value of a latching boolean in a deterministic manner. It is going to be False most of the time, unless the user just pressed the control.
- NI2: You're right. We need to prevent users from attempting to do something like that.
- NI1: We could prevent access to the "Value" Property Node of latching Booleans...
- NI2: We are already getting submerged by posts in the NI Forums... That's a receipe for disaster.
- NI3: What about we break the VI if people change the behavior of the mechanical action and there is a "Value" Property Node already on the diagram?
- NI1: Yeah, but I'd be in favor to warn the user that he/she is using a latching Boolean in a more subtle way.
- NI2: What about we pretend it's a Variant? That should raise their attention!
- NI3: OK. Anyhow, who is going to ever notice this? Let's move on to something more important like badaboom badabim...).
I don't think anybody is going to bet against you on this one 🙂
Message 10 of 11
(5,364 Views)
