Strange Error Message
Howdy...
I trying to do file reads and writes on a PowerPC
and I get the following error message:
The Date in the VI's Log file is incompatable with
the VI's front panel.
Does anyone have an idea on what is causing this?
dave
Dave Reid dave@radonc.washington.edu
UW Medical Center (206)548-4536
Radiation Oncology Dept.
Seattle, WA
(5,081 Views)
Dave Reid wrote:
> Howdy...
Oops...That should be the "Data".
dave
Seattle, WA
(5,081 Views)
You have at some point bound a datalog file to the VI.
You can unbind or change the binding in the Operate menu
under the Data Log submenu. The mesage means that you
aren't using normal file I/O, but the datalogging option.
The message indicates that you have changed the inputs
or outputs of the function since logging data.
Greg McKaskle
(5,081 Views)
