Strange behavior with Report Generation Toolkit. Table does not match array.
Hi Ben,
Have you tried the workaround that was posted?  It solved the issue for me.  It did take a performance hit, but the extra 2 or 3 seconds do not afftect the overall timeline of the test.
Let me know if you need more help.
RayR
Message 11 of 16
(824 Views)
For some strange reason my last post dissappeared...  Let me try again...
Hi Ben,
Did you try the suggested solution in one of the threads I posted earlier?  It solved the issue for me.  There was a performance hit, but the extra 2 or 3 seconds do not impact the overall duration of the test.
Let me know if you want me to post a snippet of the code I am using.
Cheers!
Message 12 of 16
(824 Views)
It seems that I cannot reply to my own thread...
I know I have been naughty, but what is going on???
It will be funny to see all three posts tomorrow..  😛
Message 13 of 16
(825 Views)
I'll try the tab for newline replacement in \vi.lib\addons\_office\_wordsub.llb\Word_Insert_Table.vi
Are there any other .vi that are affected by this issue?
Message 14 of 16
(818 Views)
Hi Ben,
I am not aware of other issues.  Below is the code I am using:
Message 15 of 16
(783 Views)
My version looks different but does match an earlier posting.  In first For loop I replaced the \n with a tab.  Then in the next For loop added string concatenate with carriage return.
My generated report now is correct.
Thanks for your support.
Ben
Message 16 of 16
(759 Views)
