Strange string constant
I found this on my diagram today:
Hiding the Display Style, showing the scrollbar, Ctrl-clicking on the Run button, nothing changes anything to the big wart on the left...
Message 1 of 11
(5,665 Views)
And here is another one:
Message 2 of 11
(5,652 Views)
Both seem to work OK for me.
Lynn
Message 3 of 11
(5,649 Views)
You mean if you drag the snippet into a diagram, you don't get these bizarre, fat edges?
This works on my end.
Message 4 of 11
(5,636 Views)
The appearance for both the snippets are wiered compared to the normal string constant
Message 5 of 11
(5,612 Views)
X,
Does this behavior occur when you place a new string constant on your diagram? Have you been able to reproduce it beyond the two cases you’ve posted?
Message 6 of 11
(5,542 Views)
I don't see any pictures or attachments in your messages.
Just text that says Strange string constant.png and Another strange string constant.png
Message 7 of 11
(5,527 Views)
Yes, dragged to my own diagram, they look as bad as the snippet. Strange....
Message 8 of 11
(5,517 Views)
A couple more:
It looks like some kind of warts... Am in trouble Doctor?
Message 9 of 11
(5,424 Views)
X. a écrit :
A couple more:
Looks like someone tampered with the default string control. Usually you don't have the advanced - customize... option enabled on the default string constant. If you opened it and make some small changes like setting it to justify or making it wider. Then when you apply changes it goes back to normal.
Strange...
Ben64
Message 10 of 11
(5,398 Views)
