Strange undo behavior
Check Tools->Options->Environment and make sure that Maximum Undo steps isn't accidently set to 1.
Edit:
Oops, just saw in the Opening post that you set it to 99.  Does it have the same effect when you set it to default or 10?  99 might be over a limit or something.
Message Edited by Mythilt on 08-05-2008 12:54 PM
Jon D
Certified LabVIEW Developer.
Message 11 of 20
(2,561 Views)
Jon D,
I can set the undo to any number, but only in this one vi (the main vi of my program) I have only one undo.  The subvi's all have multiple undos, and other vis I open have multiple undos.
And if I open this one vi on other PCs, it still has only one undo...
Strange!
Mike
Message 12 of 20
(2,543 Views)
Hi All,
As was mentioned earlier in this thread, there are a few known instances, and possibly some stranger unknown ones, where the Undo list is cleared.  There was a fix applied in LabVIEW 8.6 to try to address this issue.  Hopefully the behavior you are seeing is now fixed in 8.6!  And I apologize for any inconvenience this has caused.
Cheers,
Brian A.
Message 13 of 20
(2,523 Views)
Brian,
So I guess the undo list is somehow tied to the VI, and this particular VI will not allow an undo list greater than one item.   Strange...
Mike
Message 14 of 20
(2,509 Views)
Just curious Mike - what is the function of your VI? Mine is using ActiveX to work with some Excel spreadsheets, in LabVIEW 8.5.
Message 15 of 20
(2,503 Views)
It's the main vi of my application.  It's got about 200 subvi's in it...and all of them can have multiple undos...but the main has only one.
Mike
Message 16 of 20
(2,498 Views)
Six years after the original post, now running LabVIEW 2013 SP2, and this problem apparently still exists for some of us.  I have a top-level vi created in an older version of LabVIEW (recompiled to LV 2013) which allows only a single undo step while its sub-vi's and other top-level vi's permit the maximum number of undo steps as specified under Environment Options.  An explanation or solution would be much appreciated.
Message 17 of 20
(2,275 Views)
As soon as you Save the VI, the undo history is lost.
LV builds the undo steps, up to the specified limit, until the VI is saved.
Message 18 of 20
(2,270 Views)
Can you attach a simplified version of the VI that only allows a single undo step?
Message 19 of 20
(2,268 Views)
Inexplicably, after some extensive editing, the top-level vi that previously supported only a single undo step now supports multiple undo steps.  Smiley Frustrated
Message 20 of 20
(2,237 Views)
