Stream 2 x 120 fps cameras to disk ... HDD can't keep up?
Don't forget 2 streams. 2x290 = 590MBs
Message 11 of 15
(793 Views)
I think Dan has the right calculation for color images - just under 300 MB/s.  I assumed these are grayscale images, which is just 8 bit depth, which gives you just under 75 MB/s.
Bruce
Bruce Ammons
Ammons Engineering
Message 12 of 15
(791 Views)
2 streams is included in the 240 fps - 120 fps per camera.
Bruce
Bruce Ammons
Ammons Engineering
Message 13 of 15
(785 Views)
Dan is right, 32 bit color depth is of course 4 byte, not 2.... and Bruce is right about the cameras, i just put them together in that estimation.
Sorry for confusion.
Norbert
Norbert
Expert: Geometry
Message 14 of 15
(769 Views)
Hi friends, I see you all have experience in stream video with labview. I am trying to capture video from a streamer (gstream exactly) but all tries don't work. The reason is that I don't know how the video is stream and how to pass string received from a socket to LabVIEW. In other words, I receive the data string but not how to compose it in a video inside labview. I appreciate any help you can give me, thanks.
Message 15 of 15
(741 Views)
