Stream Digital waveform to disk
 I need to constatnly monitor a set of digital outputs during a vibration test for any false alarms.
I am using a Measurment Computing USB-1024LS (because that's what we have).
I want to stream eight alarms to disk like a chart recorder with a (seperate if need be) time index of any changes that occor.
I have been experemening with the Write Waveform to File and Export Waveform to Excel vi's but neither oen really gives me what I want.
The Write Waveform to File writes a file that I can not use because I do not know what format it is in.
The Export Waveform to Excel sort of works but the time stamp loses resoultion, and it puts an empty line betwean each reading.
What is the best way to accomplish tihs?
=== Engineer Ambiguously ===
(2,891 Views)
(2,846 Views)
