Streaming Individual Channels to File
     Im new to labveiw and if there is a better way to do what im proposing im all ears. Basicaly I am going to be collecting 12+hours of data at 51200Hz on 128 Channels, 32 channels per cDAQ Chassis. Lets start with a simple case of 1 cDAQ chassis and 32 channels at 51200Hz. By my calculations this could be a 300+GB file if i were to write it as one array, as i am now. It would be ideal if i could write each channel to its own binary file, is there a good way to do that? Any help is very much appriciated.
(2,675 Views)
Good Afternoon,
I believe that you would have to create a separate DAQmx task per channel to do this.  However, belopw is a KnowledgeBase article detailing how to write to a binary file.  Hope this helps!
AE KB 2N1DMKM5: How Can I Write and Read Binary Files Using LabVIEW?
http://digital.ni.com/public.nsf/allkb/A45A757C14D3421986256BEA006C547A?OpenDocument
(2,639 Views)
