Streaming to/From fpga target
Hello everyone,
I am trying to continueously stream to and from an FPGA target using DMA FIFOs. For that I have used two while loops. I used two loops because I am practicing to do the same for generating and acquiring signals with a real time device. The VI works fine except that is not stoping. It is not responding to the stop botton attached to the loop condition. Does anybody know why ?
(2,695 Views)
My guess is you use one button for the two loops. If the button is latching, the first read will reset the value, the second loop will continue.
Not a lot of people use NXG, you might post some screenshots.
(2,674 Views)
Accepted by wiebe@CARYA
Thank you Carya,
The problem was in the handshaking in the FPGA code.
One stop button works also but two should also work if for example I want to stop only one loop and keep the code executing with the other one.
Ali
(2,630 Views)
Ok, I accepted that as solution, so others will see the thread is solved.
(2,626 Views)
