Streaming waveform data from VeriStand
 Hello together,
I have a PXI system with which I want to record data using VeriStand. At the same time, however, the data should be presented to me in a low data rate on my LabView VI. Two examples given by LabView seem to me to be possible. On the one hand: "Deploy and Read Multiple Channels" where I cannot access the PXI system via IP address. (Invalid URI: The host name could not be parsed) And on the other hand, the possibility via Waveform Streaming, where I cannot enter a correct path here (Path in my case: //10.138.5.169/Targets/Controller/Hardware/Chassis/DAQ/PXI1Slot7/Analog Input/AI0)
What can be the problems, or what is a correctly entered path or IP address?
Best regards
Message 1 of 1
(1,434 Views)
