Stress Strain Measurement
I am doing a school project that involves gathering stress strain data from a SCXI1000 chassis.  It is equipped with a 1520 card w/SCXI 1314 terminal block connected to an extensiometer and strain gage.  It also has a 1120 card w/SCXI 1303 terminal block with type K thermocouple installed.  The SCXI1000 conditioned signals are fed into Labview 8.6 through DAQmx.  I need a Labview program to display a graphical plot the of stress/strain while testing a specimen and then save that data to a text file for later analysis.  What is the easiest way to get this done?  In the future I would also like to include an ambient temperature monitor while testing.
(3,352 Views)
I'd recommend you look in the example finder.  There are numerous DAQmx examples to show you what you want to do.
(3,335 Views)
