Strict Type Definition Troubles with Indicator/Controls
I'm working with LabView 7.0 under WinXP and it's a complex application.
I use a lot of Strict Type Definition to get consistent named and
looking *clusters* which often are composed of arrays and numerics and else.
They just look very different when they are used as controls
respectively indicators. This I think is due to the Increment/Decrement
which make a bigger distance between two elements of the array and
between the arrays, too.
AFAIK yet I can only have the indicator *or* the control with a nice skin.
Any ideas how to work around this item??
Urs
(2,987 Views)
Depends on how far you really want to go with this, and whether these are being used on a front panel that gets displayed to a user. I understand what you're saying, and this is more of an aesthetic question, but if you're creating controls/indicators of these typedefs for subVIs whose front panels don't get displayed then does it really matter what they look like? You could hide the increment/decrement for the numeric controls (right-click on the control and go to "Visible Items", uncheck "Increment/Decrement").That would make them look like the indicator counterpart, but then you lose the capability of the increment/decrement. If you don't care about that, then that's something you can do.
Message Edited by smercurio_fc on 03-21-2006 10:24 AM
(2,981 Views)
Another thought:
1) Make them typedefs and not Strict typedefs.
2) Create a typedef and use that in two new strict-typedefs, one for controls, another for indicators.
Ben
(2,975 Views)
