String Array Sorting
Question 1. Anybody know how to easily sort a string array?
Question 2. Is there any good data base management VI's out there anywhere?
Thank you
(3,246 Views)
There is this icon in the Array palette called Sort 1D Array. You might want
to give it a try.
There may be some freebie stuff floating around, but I know that NI has
an SQL add-on for communicating with most standard databases. As mentioned
in a previous posting this morning, you can also use ActiveX if that is
more convenient/easier for you. From my experience, most people find the
SQL approach easier once they get past the three letter acronym.
Greg McKaskle
(3,246 Views)
