String Arrays
How do you create a constant string array in LabView 6 suitable for input to
the Match First String function?
Thanks...Ed
(3,190 Views)
If in doubt, rt-click on the terminal and select create Control or Constant.
I've attached a quick-example that should point you along. Basically the input is an array with strings as the elements.
(3,190 Views)
This vi is mostly incorrect, and I added a corrected one (8/5).
(3,190 Views)
Ed, This is a correction to my answer of 8/4. (don't know what I was thinking yesterday...).
This corrected example shows how to create the constant array you ask about. Its done on the block diagram with strings, then through a build array, then input to terminal of said VI. I put some test data in the attached with another explanation to show.
Doug
(3,190 Views)
