String Ctrl-C/Ctrl-X Bug
@JÞB wrote:
Clipboard operations need to expire the same way the dodo did.
You mean the last female clipboard operation going over the cliff to try to grab the last watermelon? (Ice Age 1 or 2, whichever)
Sorry, it's Friday afternoon...
Cameron
To err is human, but to really foul it up requires a computer.
The optimist believes we are in the best of all possible worlds - the pessimist fears this is true.
Profanity is the one language all programmers know best.
An expert is someone who has made all the possible mistakes.
To learn something about LabVIEW at no extra cost, work the online LabVIEW tutorial(s):
LabVIEW Unit 1 - Getting Started</ a>
Learn to Use LabVIEW with MyDAQ</ a>
Message 11 of 50
(3,437 Views)
The clipboard is an effective means for user mediated intra- and inter-process communication.  It is the last resort for programmatic IPC, ie. do not mess with the user's clipboard.  I even resort to temporary files before the clipboard for that.
But, my point is that what LV does in its own house (ie. what developer's use) is far different than what LV-based applications can get away with in the real world.  Try skipping clipboard support in your next app and tell the customer you think the clipboard is too old-fashioned and should go away.   (and if said customer is me, start ducking.  I wouldn't really be throwing something at you, it is just that your head may get in between an object in my hand and the nearest wall).
Message 12 of 50
(3,431 Views)
I read through this thread and I agree that this is a bug. I filed CAR 428102 for it. It is a non-standard behavior compared to other programs that allow ctrl+c or ctrl+x as shortcuts, and as Darin said, this is not a great experience for end users.
Jeff Peacock
Product Support Engineer | LabVIEW R&D | National Instruments
Message 13 of 50
(3,418 Views)
Clipboard is marginally effective (and unfairly limited)
But that's not the point I tried to make.  The Point being Ctrl+C Ctrl+V work the way they always worked in LabVIEW.  The mere issue that the behavior (with an empty clipboard) is out of line with other applications just does not register on my "Oh-**bleep**OMeter"
IDN Drivers billed as "Plug-n-Play Project style" that are poorly organized llb's rank higher in my opinion.  Heck, fix the VISA.User Data bug first (and I don't often use that property)  Clean up FTP, bring TDMS Viewer BD into spec, add some of the advanced string functions to the palattes, obsolete the RCM option to "replace case structure with stacked sequence."
R&D has better things to focus on.
Message 14 of 50
(3,378 Views)
Jeff, you will notice that I did not instruct NI to correct this bug ASAP. In fact, if you have a way to actually set the priority of what NI is working on, please let me know, as I would definitely have a long list to submit (not including the one reported in this thread, which is a minor cosmetic annoyance).
Message 15 of 50
(3,369 Views)
I guess not too many users today are familiar with the old dos-shortcuts of shift-insert, ctrl-insert and shift-delete. This thread remembered me of them, and they work. 🙂
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 16 of 50
(3,284 Views)
Are you kidding?
Until I read this thread, I had never tried ctrl-c or ctrl-x with nothing selected (why would I?).
The level of annoyance that this bug causes is infinitesimal.
Message 17 of 50
(3,262 Views)
@paul_cardinale wrote:
Are you kidding?
Why would you?  Because there are a few programs out there that allow you to Ctrl-a Ctrl-c to quickly copy the entirety of a text block.  Users try that in a LV app and get ac inserted somewhere in the string.  That is how things get pressed with nothing selected.
Some of us endeavor to produce professional, polished software using LV and pay sufficient attention to details to be annoyed by this.  Each little mess that I no longer have to clean up helps going forward.  Bugs that propagate from LV into my programs are more annoying to me than bugs that only get me during development.
Message 18 of 50
(3,253 Views)
I don't get "ac" inserted when I try that.
Message 19 of 50
(3,249 Views)
Try it in run mode.
Bill
CLD
(Mid-Level minion.)
Message 20 of 50
(3,247 Views)
