String Display
i want to display a string, but not so, that it shows the actual value. It should show all data sent. Is this possible?
I can only find the block to display the actual value.
Thank you in advance!
Best reards
(2,420 Views)
Hi mihamm,
Yes, sure!
You just need to collect "all data sent" in a wire (and a shift register) before displaying it in an indicator…
Keep in mind: collecting huge amounts of data and displaying that amount of data may slow down your VI.
(2,413 Views)
Perhaps you mean that you want to display non-displayable characters? Then you can right-click on the string indicator and select "Hex Display", for example. A little bit more info of what you want would be good. Some code would help (a VI).
Certified LabVIEW Architect
(2,405 Views)
Accepted by topic author mihamm
Best reards
Right-click on the string.  Select: Create -> Invoke Node -> Append String.
(2,385 Views)
Hi Paul,
thanks, learned something new (for me).
In LV2011 that method is missing, but available in LV2017…
(I still prefer to collect string data using a shift register instead of letting the FP element handle potentially large amounts of data.)
(2,378 Views)
