String Entry which has to be limited
The entry should be of the format "A-00-xxx-000" where A is a alphabet,0 is numeric and xxx is fixed cannot ne varied by user and - should remain as -,   and this will be the fixed length... is it possible? If yes , kindly enlighten me!!!
Message 1 of 8
(4,307 Views)
You don't have any readymade option available in LabVIEW but you can code it at the back. You can add "-", maintain the size and do whatever you want, remember you have to enable the option "Update while typing" in the String properties.
Message 2 of 8
(4,296 Views)
  1. But how do you make the "-" , stay there permanently???
  2. And for Updating while Typing should I Use An Event Structure??
Message 3 of 8
(4,293 Views)
Yes you have to use event structure, so when you enable the "Update while typing" the event will be fired whever you make any change at that instance itself. So based on the length of the string conactenate " - " to it.
Message 4 of 8
(4,287 Views)
Our use separate controls for the string and numerics.
Message 5 of 8
(4,273 Views)
I'm kind of thinking the Key Down? event might be better.  That way you can discard the fact the the keyboard was even pressed for an invalid input.
Message 6 of 8
(4,246 Views)
I was nearly done with that .... the only problem I had the user had to do backspaces and than re-enter the value.... but know i've completely scrapped out that part... thanks all of you guys for your help
Message 7 of 8
(4,238 Views)
This doesn't handle backspaces, either, but that'd be easy to add.
Rube Goldberg, anybody?
Jim
Message 8 of 8
(4,232 Views)
