String array to a menu control
I want to display my Sheet name in Excel as a menu selection for the user. How do i make a string array as a menu control? Example i got 5 sheet name and how do i make it as control?
(3,863 Views)
You need use a drop-down control called Menu Ring in LV terms. Wire the sheet names you got by reading from the Excel file & wire the 1D Str array to the Strings[] property of that Ring control. You are done with...
- Partha ( CLD until Oct 2027 🙂 )
(3,839 Views)
Accepted by topic author ander99
See the attached pics.
(3,836 Views)
Hi Parthabe,
Thank for your reply.
Regards
Ander
(3,812 Views)
Sorry i think i phase it wrongly. Now actually i want to output a menu control to let users to choose and once user choose will output the same string as output instead of Values as 0,1,2,etc. If i use combo box, how do i link it up to make it work?
(3,805 Views)
I got this message when i use either combo box or menu ring. Currently i'm using MS word 2003 and after i run my VI i got this error "The message filter indicated that the application is busy". Is my way of using activeX cause this?
(3,800 Views)
You need to use the same Strings[] property to write the Excel sheet names to it. And remember to keep the Combo Box as a Control, if you want the user to select an item from it during the run-time.
(3,762 Views)
