String (binary) to boolean conversion problem.
Im facing problems converting a string (presumably in the binary format) to turn on LEDs according to its respective weight. ie.binary input = 1010. Thereby it would turn on the first (MSB) and third LEDs while the second and third are left off.
What I have managed to obtain is a direct conversion of decimal to binary but have not much idea on how to achieve the above goal. The attached file shows two operations; top part does the boolean to binary conversion is fine. The bottom is supposed to be the binary to boolean conversion.
(8,223 Views)
1) Right click on the "String to Boolean" control (by the way this is a numeric control not a string)
2) Select display format
3) Select binary
It is a smarter way to this, but I have to go now. Other may help you with that solution
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
(8,219 Views)
(8,217 Views)
OK, let's back up a second here. I don't understand what your "boolean to string" VI is doing. Are you starting with a string, a number, or a bunch of Boolean controls? The top part is dealing with Boolean controls and creating a string of characters of "0" and "1". The bottom part you have a numeric control. By the way, it is pointless to take the output of Number to Boolean Array, converting it to an array of 0s and 1s, indexing out each element, and then using the Not Equal to Zero operator. Just take the Boolean array output from Number to Boolean Array directly into an Index Array!
You seem to be saying that you have a string in the binary format. This is somewhat meaningless, so I'm assuming you mean you have a string that consists of a sequence of the ASCII characters "1" and "0" to indicate a numerical 1 or 0. You then want to convert this into something that is programmatically useful. What that is is not clear, so let's assume an array of Booleans. If that's the case, then you can simply take advantage of the fact that you're starting out with ASCII characters, and use the ASCII codes to find out what you have. The ASCII code for the character "0" is 30 (hex) or 48 (decimal). The ASCII code for the character "1" is 31 (hex) or 49 (decimal). Assuming this is what you have and what you want, then you can simply do this:
(8,196 Views)
