String controller help with showing English and Chinese without spacing
I'm having issues with unicode in labview with string controllers.
I want to be able to type english and chinese together in a single control and being able to backspace.
ex)
However when I'm using Force Unicode Text, the english letter became represented as UTF16LE and requires me to backspace twice to delete a single letter. If i only delete once, it screws up the whole input.
 ex) deleting the space between a and s
ricky48_6-1628219644870.png would  return ricky48_10-1628220553805.png ???
I've found that I could use Update Value While Typing with NI Update String in the Value Changed Event
This lets me input/backspace properly, but it also caused more bugs with the font size resizing and becoming double lined when entering long strings.
As well as scrambled overlapped characters and the display remains on the first line eventho multiple lines were entered.
Currently I have set the following
Event: SControl -> Mouse Down
Can anyone help?
Message 1 of 8
(2,651 Views)
bump
Message 2 of 8
(2,597 Views)
I had similar problem 2 years ago when creating a GUI for a customer's Russia branch.
I can't make a unicode string input work for both cases.
Maybe you can try to use 2 string inputs, one for ASCII, another for Chinese.
Let user choose which language he wants.  then you can show/hide string controls.
George Zou
Message 3 of 8
(2,578 Views)
Yeah that sounds ok, but my client wants chinese/english mixed in without having a set structure as to which language goes where in the string.
The force unicode seems to create so many bugs, from cursor position, overlapping text, font resizing and etc.
This is really frustrating with how something that is so basic is not supported nor is there any solution to it...
Message 4 of 8
(2,559 Views)
How about a .Net Textbox?
George Zou
Message 5 of 8
(2,554 Views)
Do you have any example vi of how to use/set a .Net Textbox to take chinese and english charc?
Haven't used .net with labview before and I can't seem to set the font to the textbox property.
Message 6 of 8
(2,548 Views)
Accepted by topic author ricky48
Just drop a RichTextBox on the FP.  It's a ctrl, user type Chinese or English in the box.  Just like a string control, no code needed for input.
You can use a property node to read the user input.
George Zou
Message 7 of 8
(2,529 Views)
Ok thnx, using a .net rich text box fixed all my issues with displaying in a text control.
Message 8 of 8
(2,513 Views)
