String from DLL to LabView within two odd characters
   Hello. I pass a string from DLL to Labview, and the result indicates correct, but there is two odd characters everytime "Gn"
 If the character I pass is " a ", then the result is "a Gn".
My DLL code is:
  void massiv_int(char *lv_ptr);
_declspec(dllexport) void f_massiv(char hello[]);
_declspec(dllexport) void f_massiv(char hello[]) {
 char lv_str[10];
 char *lv_ptr;
 lv_ptr = &lv_str[0];
 massiv_int(lv_ptr);
  * hello = lv_str[1];
void massiv_int(char *lv_ptr) {
 char lv_local[10] = "abcdefg";
 memcpy(lv_ptr, lv_local, 10);
 Could you tell me, what might be incorrect?
Thanks in advance.
(3,907 Views)
Hi there
simply change the code to
 //char lv_str[10];
 //char *lv_ptr;
 //lv_ptr = &lv_str[0];
 massiv_int(hello);
 //massiv_int(lv_ptr);
 //*hello = lv_str[1];
The original line  "* hello = lv_str[1];" just sets the FIRST character in the character string "hello" to the first character in the character string "lv_str", which is 'a'. The rest of the characters in "hello" stay uninitialized, so they contain garbage.
Best regards
chris
CL(A)Dly bending G-Force with LabVIEW
famous last words: "oh my god, it is full of stars!"
(3,899 Views)
Thank you very much, now it works.
 But what to do If I want to go to next line?
I mean output should be like:
  ______________
 | abcdef                |
 | qwerty                |
 |_______________|
 void massiv_int(char *hello);
 massiv_int(hello);
void massiv_int(char *hello) {
 memcpy(hello, lv_local, 10);
 then massiv_int() calls another function which contain string "qwerty"
Message Edited by ACiDuser on 10-08-2008 05:17 AM
(3,891 Views)
Accepted by topic author ACiDuser
Try this:
void massiv_int_NextLine(char *lv_ptr);
LVSTR_API void f_massiv(char hello[]) {
 //char lv_str[10];
 //char *lv_ptr;
 massiv_int(hello);
 // make lv_local as long as needed (no extra characters)
 char lv_local[] = "abcdefg";
 // copy all characters in lv_local to lv_ptr
 strcpy(lv_ptr, lv_local);
 // add next line
 massiv_int_NextLine(lv_ptr + strlen(lv_ptr));
void massiv_int_NextLine(char *lv_ptr){
 // make lv_local as long as needed (no extra characters, including LF)
 char lv_local[] = "\nqwerty";
 But make sure the external string buffer allocated by LV is long enough to hold all characters!!
Best regards
chris
(3,882 Views)
Thank you! 🙂 it works perfect
(3,868 Views)
// DLL for LabView
// “lv_read( )” function passes two row string to LabView
// declaration of two sub-functions
void func1(char *lv_str);
void func2(char *lv_str);
_declspec(dllexport) void lv_read(char lv_str[]);
_declspec(dllexport) void lv_read(char lv_str[]) {
 func1(lv_str);
void func1(char *lv_str) {
// make array_local as long as needed (no extra characters)
 char array_local[] = "abcdefg";
// copy all characters in array_local to lv_str
 strcpy(lv_str, array_local);
// add next line
 func2(lv_str + strlen(lv_str));//“+ strlen(lv_str)” moves pointer to the end of existing string
void func2(char *lv_str){
 char array_local[] = "\nqwerty"; // “\n” throws to the next line
(3,863 Views)
