String problem
I am trying to read information from an encoder in order to control the position to a motor.
However, when I try to read the encoder information, I seem to get a hexidecimal number I can do anything with. Does anyone know what I can do to get a integer value from the encoder.
Any help would be highly appreciated
Vegard
Message 1 of 10
(6,666 Views)
Accepted by topic author Vegard123
Hi Vegard,
posting an image is better than just writing text. But posting a VI/snippet would be much better than a simple image!
I guess your string indicator "EncCnt" is set to "Hex Display" mode. If this is the case you should typecast the received string to an U32 value…
Or use DeserializeString:
Message 2 of 10
(6,627 Views)
I see.
I will try to convert it to U32. Thanks!
Message 3 of 10
(6,600 Views)
 I tried to typecast the string, but the info I got out of it was weird I think. It did not return numbers, just weird letters..
Message 4 of 10
(6,589 Views)
Hi Vegard,
sorry, can't open your LV2015 VI. Please downconvert to LV2011 (or LV2014)…
Message 5 of 10
(6,575 Views)
Why are you typecasting a string into a string?  That does nothing.  Instead, wire an U32 into the "type" input.
Message 6 of 10
(6,562 Views)
That is what I am trying to do, I inserted Control into the type input, but I could not seem to be able to put U32 into the typecast..
Message 7 of 10
(6,551 Views)
Sorry, figured it out. Really simple, but not so easy when I am new to the program
Message 8 of 10
(6,547 Views)
Why don't you post your solution instead of just saying you fixed it so other people can benefit from your experience?
This is a chance for you to be the teacher in a learning forum.  🙂
Bill
CLD
(Mid-Level minion.)
Message 9 of 10
(6,528 Views)
Would gladly post my solutions. Right now it is packed into quite a bit of code. But the thing was really to make a numeric constant and change the representation to U32. Then wire it to the 'type' terminal on the type cast block.
If anyone should ever be interested, this is the VI i made for rotating one rev forwards.
Message 10 of 10
(6,493 Views)
