String to 2Darray
I am trying to create a 2d array(double) from a string of floating point
numbers(4 in a row and running into several lines). I am using the
function 'spreadsheet string to Array' and have wired '%f' for format string
conversion and null string for 'delimiter'. The output indicator shows only
the first column of the array correctly but the other (3) columns are not
shown indicating the output is only a one-dimensional array!
I can email the VI if someone is prepared to debug and let me know.
Many thanks in advance.
(2,828 Views)
Sheela Belur wrote:
> Hi,
Instead of using the "Null" string for a delimiter try either a TAB or several
spaces.
Depending on how the data is formated.
This function expects to see the data as follows
data 'delim' data 'delim'
data 'delim' .......
data 'delim' data 'delim' data 'delim' .......
When you put the null string in, the function thinks it has the EOL so it goes
to the next row of data.
As far as I understand the question this is what you are seeing.
Kevin Kent
(2,828 Views)
