String to PSP Variable?
I was hoping that I could programmatically buid up a shared variable path, and then use the Read Variable VI to read a value.
Unfortunately, while I can convert a PSP Variable into a string, I can't do the reverse. The output of the String to Shared Variable VI is not recognized by the Read Variable VI. I tried to convert it to a PSP Variable using To More Specific Class, but LabVIEW wouldn't allow it either.
Is there a way to convert a string into a programmatically-readable shared variable?
Thanks!
Certified LabVIEW Developer
(3,990 Views)
Accepted by topic author JKSH
DUH... I can use the Seach Variable Container VI, like the start of my posted code... X_X *slinks away in embarassment*
(3,985 Views)
