String to Substring to Cluster
Hello, I'm trying to write a VI that parses a given string into substrings and displays the results in a cluster using Keys and Fields.
I created a VI that separates the strings and put them into clusters, but it's not using Keys and Fields. Everything I find on the topic is complicated and I don't understand.
I need to be able to
  • parse the sentence case-insensitively
  • handle the keys and fields in any order
  • extract substrings into a cluster
(3,390 Views)
Handling them in any order seems like an unreasonable constraint to me.  Data like this are always going to be arriving in order.
Bill
CLD
(Mid-Level minion.)
(3,370 Views)
Not necessarily,  some of the data may simply change. Assume Emma contracts COVID during a hospital stay recovering from mastectomy / addadictomy surgery over a birthday. Eric, now identifies as Male and aged to 37.
And here is where we point out the advantage of using bundle by name instead of bundle and extracting the keys from the array of K-V pairs in a loop.
(3,326 Views)
  • The order and name of cluster elements will not change (make it a typedef to be sure!), but the order of key/value pairs in the input string might, depending on where it is coming from.
  • Don't use array to cluster!!! That's completely pointless here
  • Create the cluster by looking up the desired fields in an array of keys, then process accordingly (string, decimal, boolean, etc.)
Here's a quick example (even returns some sentinel values for missing fields):
There are many other ways to do this, of course.
Original order:
Different order, same result:
(3,317 Views)
I thought the OP meant truly random, like keys sometimes arriving before the associated values or sometimes after.
Bill
CLD
(Mid-Level minion.)
(3,303 Views)
If the values not follow their key, all bets are off. 😄
(3,299 Views)
Another possible solution is to use a regular expression to capture key value pairs, and insert them into a map where you can dereference them later. You could do this explicitly like in the snippet below, or you could index the map into a For Loop. When you do that, the keys are indexed alphabetically (for strings).
This also works for any order, and as long as you maintain the map for each person, then it could work for partial data as well.
Wes Pierce
Principal Engineer
Pierce Controls
(3,291 Views)
