String to array - more elegant solution possible?
Hello, I have a string that contains different status information. These are separated by \n\r. Now I would like to transfer each status message into an array field. My solution works, but I find it very complicated. Does anyone have an idea to solve it more elegantly?
Thanks a lot for your help.
Michael
(4,239 Views)
Yes, it looks complicated…
There surely someone comes up with a RegEx solution to filter all those EOL chars…
(4,226 Views)
Qestit Systems
Certified-LabVIEW-Developer
(4,223 Views)
(4,189 Views)
@Yamaeda wrote:
I would have done this except leave the delimiter unwired (the EOL is handled already in the Spreadsheet String To Array).  I have actually ran into this enough that I have a VI that does the FOR loop to eliminate empty strings in my arrays.  I also have a similar one for NaN in floating point arrays.
(4,158 Views)
Remember that "scan string for tokens" (by default) collapses multiple consecutive delimiters into one, offering yet another simple solutions:
This simplifies things, because if does not matter if the delimiter is \n\r, \n, \r\n, \n\r\n\r, etc.
NOTE: Of course this is an an opportunity to remind people of my old idea:
Contract multiple delimiters for "Spreadsheet string to array"
Please vote for it! Thanks! 😄
(4,153 Views)
If you have OpenG library, use it in the following way. Simple!
(4,136 Views)
