String to double conversion
I'm trying to convert the following string to a double:
it=55,55
Does anyone have any suggestions?
Message 1 of 9
(17,311 Views)
       Use Scan From String with input format "%,;%f" or use Fract/Exp String To Number with use system decimal point = FALSE if decimal point is "." or use sytem decimal point = TRUE if decimal point is ",".
Best Regards,
Luis A. Mata C.
Ing. Electrónico
Whatsapp: +58-414-1985579
BBM Pin: 2B83E99A
Thanks: Kudos
Message 2 of 9
(17,304 Views)
it=55,55
What are you trying to convert into a double?  The whole string (it=55,55)?  By "double," do you mean "ascii codes?"
Bill
CLD
(Mid-Level minion.)
Message 3 of 9
(17,297 Views)
Thanks for the help, however, i keep getting the following error:
Error 85 occurred at Scan From String (arg 1) in Untitled 3
Am I missing an element?
Message 4 of 9
(17,285 Views)
I'm trying to convert the number vlues into seperate double indicators.
Message 5 of 9
(17,276 Views)
       billko read better that me, change format string to:
                                          it=%,;%f
Best Regards,
Luis A. Mata C.
Ing. Electrónico
BBM Pin: 2B83E99A
Thanks: Kudos
Message 6 of 9
(17,271 Views)
Post your VI, that way we can see what you are doing wrong.
Be sure that you have any data in controls saved as the default values.
Message 7 of 9
(17,270 Views)
Accepted by topic author floresma
   Two numbers, ok.
   Try this:
PS: You can erase %.; if you system decimal point is ".".
Best Regards,
Luis A. Mata C.
Ing. Electrónico
BBM Pin: 2B83E99A
Thanks: Kudos
Message 8 of 9
(17,266 Views)
Thanks for the help:) this worked perfectly....
Also, thanks to everyone for all your feedback...
Message 9 of 9
(17,259 Views)
