String to dynamic/numeric data
I am wondering if anyone can explain to me how to convert my string data (output, see vi) to dynamic/numeric so that it is able to be displayed on a graph.
The reason that I need to do it this way, rather than make a graph while recording the data, is that I need to create a historical records of the data to future references, so a graph is perfect.
Any help much appreciated
Chaz
Message 1 of 8
(5,528 Views)
This is very basic Labview. Go to the string functions palette. You will also find all examples you need in the labview examples folder.
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
Message 2 of 8
(5,527 Views)
And you only need to read your file once. The way it's set up now your vi will read it continuously.
PaulG.
Retired
Message 3 of 8
(5,520 Views)
Here is a tip. Right click on "label" marked string below the function. You select the output type here (string,integer,double). It may solve your problem
Message 4 of 8
(5,515 Views)
Hi Chaz,
you don't need dynamic data, numeric values are enough. Which column do you wanna plot into a graph. Use the index array function to get the column you need and convert it to numeric. You can connect the result directly to a graph indicator.
Mike
Message 5 of 8
(5,513 Views)
I need to keep it as string in the array due to the fact that i need the date & time to display...
Chaz
Message 6 of 8
(5,508 Views)
Also i need to display column 3-6 as column 1 is date & column 2 is time.
Chaz
Message 7 of 8
(5,489 Views)
xXChazXx
We have all been new to labview sometime. Like you are now. But I think you should spend some more to familiarize your self with Labview. One way to learn Labview is to browse trough the labview examples. If you are looking for a specific example use the find example under help (menu bar). I am also sure your school has some Labview books. This is only a friendly tip 🙂
Good luck
Message 8 of 8
(5,487 Views)
