String to file path
I am looking for a function in LabVIEW and it seems to be hiding from me.
I have data write to a file in my VI.
There are 3 strings:
1) constant - file path preceding the name of the file
2) control - the user can type in whatever name they want
3) constant - ".txt"
The 3 strings are then concatenated.
Can I turn that concatenated string into a filepath?
It would be really cool if there was a "string to filepath" function, but I cant find it.
Cory K
Message 1 of 10
(20,264 Views)
OK, nevermind
Of course right after I post my question, I found the function moments later.
Thanks anyway
Cory K
Message 2 of 10
(20,263 Views)
Glad you found your own solution.  There are many ways of implementing your solution.  However, here are a couple of simple and straight-forward solutions that may be useful for someone reading this thread.
R
Message Edited by JoeLabView on 07-30-2008 08:49 PM
Message 3 of 10
(20,246 Views)
JoeLabView wrote:
Actually, only the lower version is acceptable here.
The upper version will fail if the path is anything but "c:\" (or similar), because you'll not get the "\" delimiter. (e.g. if path is "c:\dir1", you'll end up with c:\dir1filename.txt instead of  c:\dir1\filename.txt. It is also hard to justify the use of three operations for something that can be done in a single step.
Also, remember that "string to path" and "path to string" can often break platform independence.
Message 4 of 10
(20,230 Views)
Hi-
This thread is still relevant 5 years later...
So, if I do want to have my base path as C:\dir1\ instaed of C:\ what shall I do?
DaniDin
DaniDin
Message 5 of 10
(19,279 Views)
This
EDIT:  Just noticed I used base1 instead of dir1, but you should get the point.
Message 6 of 10
(19,269 Views)
Crossrulz-
Your suggestion to specify a subdirectory "base1" in the base path argument as: C:\base1 does not work. See the 2008 entry by altenbach. When doing that, the intended base1 subdirectory ends up being the prefix of the filename.
So, instead of obtaining: "C:\base1\filename.txt", I end up with: "C:\base1filename.txt".
DaniDin
Message 7 of 10
(19,263 Views)
The goal can be accomplished by simply concatenating the sub folder "base1\" as a constant before the filename.
So the base path is still "C:\", then in the second argument of the "Build Path" function, concatenate "Base1\ with "Filename", and with ".txt"
DaniDin
Message 8 of 10
(19,256 Views)
@DaniDin wrote:
Crossrulz-
Did you run the crossrulz post?  It works as expected returning c:\base1\filename.txt  The comment altenbach said was that you may run into issues if you just use concatenate string instead of build path.
Message 9 of 10
(19,255 Views)
You are making life too difficult.  Trust me.  The code I gave you will do exactly what you want.
Message 10 of 10
(19,250 Views)
