String to number conversion
I don't think you can't have a DBL indicator displaying that. Only string or timestamp as far as I know.
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
Antoine Chalons
Message 11 of 18
(1,517 Views)
k sir leave this here i got clear now thank you very much
Message 12 of 18
(1,516 Views)
Hi TiTou,
Exactly, I'm an ex-NI employee.
And the problem is not the evolving needs, but the lack of gratitude.
Cheers,
Olivier L. | Certified LabVIEW Developer
Message 13 of 18
(1,515 Views)
@Olivier_L wrote:
And you should try to think about a solution by yourself!
Ahem... the whole point of coming here to ask question is when you can't find a solution yourself.
Epictetus
Antoine Chalons
Message 14 of 18
(1,514 Views)
@mahi108. wrote:
output form of dbl should aslo appear as 55:06:33
it should not display  63393
You are not understanding the difference between a value and it display. The value of the number indicates a time. It can be displayed on the graph as TiTou has shown. Or you could have just started out with the timestamp as TiTou had suggested in the first place, which I think is a far easier solution.
Olivier_L wrote:
It's not possible for a numeric Control to display Time Values, that's why Timestamp controls exist!
 Says who?
Message 15 of 18
(1,509 Views)
If you convert a timestamp to a dbl, the result will be the number of seconds since 01:00:00,000 01.01.1904.
Message 16 of 18
(1,505 Views)
That's right, maybe my answer is quite "savage" Smiley Very Happy
But I'm disappointed with "kind of order" posts and waiting for ready to run solution provider.
Message 17 of 18
(1,500 Views)
OK
I Assume my mistake. Sorry for that "too quick" answer without having verified it before!
Cheers,
Message 18 of 18
(1,494 Views)
