Strings sent to .csv file are modified
Accepted by topic author MPerlick
@paul.r wrote:
It is - if instead of saving the file as a csv file, you save it as a text file, when you then try and open it in Excel it will take you through an import wizard that will allow you to specify the format of the data.
If you save the file as a txt file and have the file be tab delimited (instead of comma delimited), then Excel will open it up perfectly fine.
Message 11 of 12
(318 Views)
Good idea! I'll try that.
Message 12 of 12
(314 Views)
