Strings to 7-Bit binary
Dear Sebastian,
some years later ... I have the same issue, can you explain how you have solved the conversion from the ascii to 7-bit PDU.
Asper
Message 11 of 13
(1,332 Views)
Well, as you noticed, this is a very old thread, but the problem sounds very similar to the bit-twiddling challenge from 2002. This means that very efficient algorithms exsts, we just need to do a few tweaks to adjust the lenghts. (For some reason, the result page (link currently broken!) of the challenge has disappeared. I contacted NI to see if it caqn be restored...).
(Hint: avoid any green datatypes and do it all in blue code :D)
Does performance matter? How long are you strings?
Can you attach a very simple VI containing a typical input string and the expected result?
Message 12 of 13
(1,322 Views)
Dear altenbach,
as Sebastian, my goal is to encode an ASCII text in PDU GSM standard alphabet.
The PDU format is a 7-bit code packed in 8-bit, the 7-bit characters have a own conversion table vs ASCII.
The text length is maximum 160 character (standard SMS).
I have solved the issue, let say, by brute force, see attached image.
I was wondering if Sebastian, or someone else,  has found a more efficient solution.
Asper
Message 13 of 13
(1,291 Views)
