Strings
i was basically trying to convert a hexadecimal number to a decimal format
I made use of the inbuilt hexa to decimal converter but i would like to send more than 1 hexa data at a time...
Say something like i have many hexa values which have to be converted all at once but displayed in some sort of sequence(like in a table)
(5,003 Views)
Try formatting all your hex values into an array, then connect this array to the outside of a for loop.
This will index each of your values and you can use the same converter to change them all and output back to an array.
You can easily display the array in a table or a listbox or whatever then.
(4,998 Views)
i have tried to create an array...but that is just initialising it to a predefined value...
i want to be able to edit the values in the array
how do i do it?
(4,988 Views)
Accepted by topic author guest of ni
(4,983 Views)
By setting the array to a control you can manually change all the values in it from the front panel
(4,977 Views)
thx muks,
i have been able to get the required array format
thanks once again
(4,951 Views)
