Strip Chart From Right to Left (Or Top to Bottom.) Any ideas?
Hoping someone has some ideas.  I need to do a strip chart from right to left (Or Top to bottom.)  I have been working with an example that uses a circular buffer and XY graph, but the problem is the grid-lines do not move.
Any help would be appreciated.
Message 1 of 9
(3,843 Views)
Post your example in LV 2015 or so.
You can change the max and min of graphs to get the axis to flip (negative plotted up and positive down).
But you don't want to make anyone work too hard to help you so post your example.
Ben
Message 2 of 9
(3,838 Views)
Thanks Ben, didn't realize i could simply reverse the min/max.  Works great.
Thanks!
Message 3 of 9
(3,836 Views)
Well, I thought i was there, but still not quite how i need it.  I have attached a simple example of what i am currently doing.  It works right now if i enable autoscale on Y, but the problem is that I also need to be able to set the Increment, and minor increment for the Y axis, which i can only do if autoscale is turned off.   Does anyone know how i can get the grid to scroll with autoscale turned off? (Short of setting the range every iteration.....)
Message 4 of 9
(3,802 Views)
Well, if i set the max and min range every iteration it does work... Performance seems okay
Message 5 of 9
(3,779 Views)
In case it may help...
There is a "auto-scale once now" for scale fit property and "autoscale Delay" that delays how fast the range is reduced when the amplitude drops.
Ben
Message 6 of 9
(3,775 Views)
Hi Ben,
where do we find that "autoscale delay"?
Message 7 of 9
(3,771 Views)
In LV 2017 it is right under "Active Y Scale".
Ben
Message 8 of 9
(3,767 Views)
Hi Ben,
thanks, learned something new today!
(Never needed/missed that feature so far…)
Message 9 of 9
(3,765 Views)
