Strip Chart time shift obscures data
Im a novice and cant get my stripchart to display data like a strip chart.
Ive fiddled with Chart history length, sample rate, scaling and others but the data seems to scroll of the end of the chart and then changes in my signal are no longer displayed.
I simply want to display and record two channels.
Any help and insight would be greatly appreciated.
Ive attached the VI
Im using USB-6009 and Labview 7
(3,251 Views)
Accepted by topic author Confusion
Place the chart directly after the read function, NOT after the built array.
A chart has it's own history buffer. You can adjust the buffer size (right-click...chart history lenght...)
(3,247 Views)
Thank you very much Altenbach, You solved my problem!
(3,222 Views)
