Struggling with Converting a 2-D array of U8 data to a Matlab file format?
I am struggling trying to convert a simple 2-D array of U8 data (3 channels) to a matlab file format.  I have been manipulating the examples found in the labview2matlabni folder - but I can't get it to read in Matlab - the matrix is unreadable - says inconsistent number of columns.
I have included my vi with a sample of the data saved as input.  I am sure this shouldn't be so difficult!
Thanks in advance - any help is appreciated!
Message 1 of 16
(3,686 Views)
Do you have a link to a documentation of this file format?
You code seems overly complicated with a lot of unecessary operations. For example, to take the product of all dimensions, you could just do a "multiply array elements", no loop needed.
Who wrote the two subVIs?
For example, the entire left side of your code could be written as follows:
Message 2 of 16
(3,680 Views)
The data is just three channels of U8 data - that is it in terms of format.  I just hacked a few of the examples (LabviewtoMatlabvi) I found on the ni site with what I thought I needed to save as .mat.
Message 3 of 16
(3,676 Views)
These are all the .vis that I have found from searching the site - but none seem to work for me.  I keep getting the same error about the inconsistent number of columns and unable to extract matrix size from file.
Message 4 of 16
(3,673 Views)
I am still struggling with this problem - I cannot get this simple 3 channel array to be read in matlab - I have been exploring the matlab dataplugin but I can't make sense of it - I would really appreciate any help out there!
Thanks!
Message 5 of 16
(3,647 Views)
I do have matlab here, but I am very unfamiliar with it. Can you show a few lines of matlab code to demonstrate how you are trying to read it? This way I can do some experiments myself. Thanks.
Message 6 of 16
(3,637 Views)
Accepted by topic author PA_UW
If you haven't doen this already,
You may want to check out this site, http://matio-labview.sourceforge.net/. I believe there are VIs for saving and importing .mat files.
Cheers,
mcduff
Message 7 of 16
(3,635 Views)
at this point I am just trying to load the file in with:
load('filename.mat")
size(val)
right now I can't get passed load!
thanks.
Message 8 of 16
(3,629 Views)
size(val)
should be something like
3  277453
Message 9 of 16
(3,625 Views)
I had not seen this:  http://matio-labview.sourceforge.net/
Thank-you so much!!  I think this solves it.  Not sure what was going on with those other programs...  but this one seems to work.
Most appreciated - made my day!
Message 10 of 16
(3,609 Views)
