09-03-2023 07:20 AM - edited 09-03-2023 07:32 AM
I Need Advice on 5-Round Logic and AI Integration"
I've been working on a Tic-Tac-Toe game in LabVIEW for 7 days. I managed to build a basic game where players can take turns by pressing a start button and the game determines a winner. Initially, I used button arrays and numeric arrays, but switched to Picture Rings for better graphics. Now I'm dealing with 0, 1, and 2 as values, and it's really confusing. I feel like I'm close to getting it, but keep running into issues with value mismatches, making it hard to connect the dots. It's really frustrating. I'm stuck on implementing a feature where one side plays randomly (AI) and records results over 5 rounds. I keep encountering errors and can't seem to find a solution. I admit my understanding of LabVIEW is quite limited. Would anyone be willing to review my code and offer some advice? I'll attach the code file. Thank you!
Solved! Go to Solution.
09-03-2023 09:00 AM
I haven't looked at your VI yes, but maybe you could have a look at my very old 4x4 code for some ideas.
09-03-2023 09:09 AM - edited 09-03-2023 09:13 AM
Sorry, I currently cannot inspect your code because I only have LabVIEW 2020 on my laptop here. Consider "save for previous" before attaching. Also make sure that it is runnable and includes all dependencies such as subVIs and sound files.
Also explain what the difference between the two attached VIs are.
Just looking at your code picture, you seem to be completely missing the spirit and power of dataflow. I am guessing you are a text programmer and retain habits that are basically wrong here. Maybe you should start with some tutorial.
You seem to have all controls and indicators disconnected, then shuffling all logic around with value references and local variables. none of those are needed!!! In LabVIEW, the wire is the variable and data that needs to be maintained across iterations belongs in shift registers. You have glaring race conditions. Properly programmed, you code could easily fit on half a postcard.
09-03-2023 04:12 PM - edited 09-03-2023 04:56 PM
I've downgraded the version.
I also realized that I need to resolve the issue with the WAV file paths.
V1 is functional but lacks AI capabilities and a detailed case structure.
V2 is not operational; I was attempting to account for every possible scenario through various cases.
I've looked at a variety of samples in LabVIEW, including 4x4 grids and three-level difficulty AI. While they are impressive, simplifying the more complex versions to fit my needs has proven to be quite challenging. Right now, I'm trying to build upon a simpler version, but even that isn't easy.
09-03-2023 04:31 PM
So what's the difference between V1 and V2?
I recommend to use relative paths (relative to the current VI) for the sound files. It is unlikely that most users have folders in a "C:\Users\zubat\OneDrive\Desktop\TTT\... " hierarchy.
09-03-2023 05:24 PM
09-03-2023 05:41 PM
No, V1 is NOT functional by any definition of the term. 😄
To get you started, here's a quick rewrite of the basic functionality. Just add a subVI to score the board and returns: Xwins, OWins, Tied, or "keep playing", for example. Depending on the outcome you can then increment counters held in shift registers (not shown).
I strongly recommend to get rid of all these silly sounds. That's the very last thing to add once the code works.
09-03-2023 06:08 PM
@altenbach wrote:
Just add a subVI to score the board .
Here's a very simple draft how it could be done:
09-04-2023 03:53 AM - edited 09-04-2023 04:08 AM
Thanks to you, I've been able to progress this far after about 4 hours of tinkering. What I'm unsure about now is what kind of structure (event or case) would be best for implementing a Player 2 AI that makes random moves. After the player clicks and selects a value, I need the AI to randomly choose one spot among the spots with a value of '2'. I'm not sure how to best implement this feature. Should I implement it as another case structure within the central case structure labeled '2' that triggers depending on the player's turn? I'm also wondering how to continue the game for up to 5 rounds while recording the score of the player.
09-04-2023 12:09 PM - edited 09-04-2023 12:10 PM
You again failed to "save for previous" before attaching, so I cannot look at it until later. Also never (never ever!) attach new code with the same name as the old code! That can cause a lot of confusion because the browser will rename the files to keep them unique (e.g. "TTT (1).zip") and it is confusing to remember what's what.
From what I can see from the picture, you are still falling into your old habits using terminals as "variable" and read/write to them using locals. This blurs the distinction between control and indicator and can cause race conditions because it is not obvious to see what wrote to it last! (when programmed with wires, you can just "follow the wire" to see where the value comes from and what depends on it. Much cleaner!) For example why is the "winner" terminal disconnected? If you would place it after the case structure, you can output different strings from different cases (even empty strings!) to the same terminal. no locals needed!
Your counts belong in a shift register that you update in the relevant cases, not ping-ponged around via locals.
You don't need the big index array for the sound paths resulting in many wires going into the rest. Just wire the array into the code and index one where needed and play that sound.
