Struggling with simple serial comms
Hi all - been hacking away at something that should be simple for hours now, so I'm gonna ask for help...
I have an RS-485 device connected to COM5 via a USB adaptor, running at 9600 baud, 0,8,1,none - basic serial parameters. I can talk to the device using it's native terminal software, and even using hyperterminal with the above settings. It seems a no-brainer and so I thought LabVIEW and VISA would connect without much effort.
So I use the following simple sequence in LabVIEW:
- VISA configure serial port, 9600,0,8,1,none (no errors)
- VISA set buffer size, 4096 with a mask of 48 (no errors)
- VISA flush buffers, both buffers (no errors)
- VISA write, command string is "PR C2\r\n" which should be echoed, and return a numeric value (normally 0)
- check bytes at port property; returns 12
- VISA read, returns the command string only, 7 bytes
why can't I read the full buffer ?
To be honest, I thought this would just work with a trivial serial program: configure-write-read. But that always generates an error. I've added the buffer size since doing a bit of research and that makes it error free at least, though it's not in any of the published examples.
I don't think it's a delay issue, since I add plenty of delay when I'm debuging, and I have tried putting delays before the read. The fact that the byte count in the buffer is 12 seems to indicate my response is there somewhere...
I've also tried a second read but it doesn't return anything.
regards,
Lamb
(4,998 Views)
Accepted by topic author RichLamb
Just disable the termination char.
That is the reason you only get one line.
Or do a second read at the end.
(4,991 Views)
Hi Lamb,
maybe you enabled the termination character. And in your example the "\r\n"  are on position 6 and 7.
Mike
(4,990 Views)
Yeah, you guys are correct, and it seems so obvious now! That termination char is effectively being "recycled" since the command is being echoed.
Disabling the termination char fixes it. I also have the option of disabling the echo from the device...
thanks for the help
(4,954 Views)
