Student. Extremely new to LabVIEW. Have a very simple question for a project I am doing
I am currently an Undergraduate studying Industrial Tech. I am working on a project for LabView and have a simple question. For the project I have to design the front panel of a soda machine. If the amount of money entered is lower than the amount of money needed, it needs to have a numeric indicator displaying the amount needed. I have attached a picture of the problem I'm trying to solve above. I have to subtract the total cost from the amount of money entered. The problem is of course that when I do this, if I have entered more money than needed, the "Amount Needed" box will display a negative number. So I made it run through an absolute value node to make it positive, but of course now it shows that there is money needed even if I put more than is needed. So how can I make the "Amount Needed" indicator only display negative values, while also sending it through an absolute value node to make it a positive value? Any help is greatly appreciated. Thanks!
(3,182 Views)
You need something to make a decision. If the difference is negative, then more money is needed. Look on the comparison palette and then use a Case structure.
You should probably have a loop around your code so that the user does not need to enter all the data then run the VI.
Lynn
(3,176 Views)
Ah yes, thank you! That did the trick. I attached the solution that I worked out. I appreciate the help, I know how to use case structures now!
(3,171 Views)
